Author Topic: Blizzard 600 triple  (Read 4467 times)
Transformer86
  • Stock Racer
Blizzard 600 triple
« on: January 21, 2021, 04:42:29 am »
I’ve been on this site for years and enjoyed all the builds. Here some pics of my finished build.
    shane lang
    Re: Blizzard 600 triple
    « Reply #1 on: January 21, 2021, 11:59:38 am »
    Very cool. It flows together quite nicely. Similar design elements in the hood and seat. Nice build!
    DJS800
    « Reply #2 on: January 21, 2021, 12:05:24 pm »
    That is cool, do you have pictures of the build?
    Transformer86
    • Stock Racer
    « Reply #3 on: January 21, 2021, 03:36:18 pm »
    Unfortunately I don’t have any pics of the build.
    pma1123
    « Reply #4 on: January 21, 2021, 04:40:52 pm »
    Awesome build Transformer86!!!   Thanks for sharing!!!   8)
    Looks like the powertrain donor parts are 97 F3.....could you share some other details?
    Guessing 02 MXZ-X wide running board/tipped tunnel?  Or maybe 03-04 rev tunnel, but has trailing arm mounts?  :o
    The sum of the parts works together really well.
    « Last Edit: January 21, 2021, 05:05:02 pm by pma1123 »
    Transformer86
    • Stock Racer
    « Reply #5 on: January 21, 2021, 08:00:34 pm »
    Thanks.
    Your right it’s a 97 Formula lll 600. Stock pipes with the covers removed for clearance. I just had to message pipes to fit with a Dynoport can. I shortened  the height of airbox’s by 2” to fit under hood.
    The drive train is all from an 97 S2000. 23/44 gearing.
    The hood from an 80 Blizzard 7500. I installed 97 gauges and headlight
     The tunnel is actually made from 3 different tunnels a 9500 And 5500 Blizzard and a Rev. I like the tipped tunnel look so I used a Rev heat exchanger which worked in my favour because the Blizzard tunnel is 1” wider so I cut tunnel to fit. Rear section of tunnel that holds 2008 XP snow flap and bumper from Rev. Mounted the Rev running boards the original were to short . The Blizzard hood was 4” narrower the original so I removed foot rest. I made bracket to pull the belly pan 2” in on both sides to fit 9500 bumper, hood and moved my foot position more foward. I used a F chassis steering post. I moved it 10” forward to get the rider forward position Rev rear pyramidal chassis pieces to strengthen post bracket it also holds the Rev fuel tank and seat. 2005 Mach z handle bars.
    Rear suspension is from an 2005 Arctic Cat 136” 13.5” travel  1.25 lug track
    Build took 4yrs on and off.
    Transformer86
    • Stock Racer
    « Reply #6 on: January 21, 2021, 08:06:24 pm »
    Forgot to mention that bulkhead, belly pan and front suspension are S2000 chassis. I trimed the moulded bumper off to fit Blizzard bumper.
    toocheaptosmoke
    • Keepin' it old school
    « Reply #7 on: January 23, 2021, 02:16:02 am »
    Now that is cool, love all the different parts!  8)
    https://www.youtube.com/user/toocheaptosmoke
    If you don't have too many projects, you don't have enough!
    - Barn Fresh Racing -
    Skier76
    • CT and Southern Vermont
    « Reply #8 on: January 23, 2021, 08:48:36 pm »
    Wow! That's cool! What a nice mix of parts that came together seamlessly. And the poop emoji cracks me up!
    2002 Z570 SS
    2001 Panther 440
    HudCo
    « Reply #9 on: February 20, 2021, 01:34:07 am »
    thats one of my favorite hoods
    « Reply #10 on: February 20, 2021, 12:29:08 pm »
    Nice work. I'd imagine a lot of thinking when into this sled. You must be a good welder melting those different chassis together.  :)
    When I grow up, I want to be a biker. But Mom says I can't do both.
    Earl
    « Reply #11 on: February 20, 2021, 01:03:30 pm »
    you should be very proud of your work!
    Transformer86
    • Stock Racer
    « Reply #12 on: February 24, 2021, 12:44:51 am »
    Thanks. Actually the only welding I did was on the steering post, oil and coolant bottle mount. Everything else is either riveted or bolted on.
    ski-doood
    « Reply #13 on: September 28, 2021, 03:01:02 am »
    That is an awesome build and what a headturner it must be.  I bet with the Formula III motor and factory PIPES it must sound as good as it looks.  Nice build!
