Author Topic: El Tigre 5000  (Read 589 times)
Tiger5
El Tigre 5000
« on: July 11, 2021, 07:12:30 pm »
I have a 1980 Arctic Cat El Tigre 5000 with the 500cc free air. Starts okay when engine is cold, once it warms up and I try to restart it, it rips the pull cord out of my hand like it's trying to run backwards?? I'm totally stumped. Any suggestions would be appreciated.
    shewelt
    • Timing keeps everything from happening all at once
      • FIREPLUG CDI's FOR VINTAGE SNOWMOBILES
    Re: El Tigre 5000
    « Reply #1 on: July 11, 2021, 08:08:42 pm »
    Appears your CDI is failing.  Causing the spark to happen at the wrong time.  I've heard of it often happening.
    Check it out!  www.CDIBOX.com
    Tiger5
    Re: El Tigre 5000
    « Reply #2 on: July 11, 2021, 08:42:25 pm »
    Thank you very much. I've been at a complete loss.  :)
    Tiger5
    Re: El Tigre 5000
    « Reply #3 on: July 23, 2021, 09:36:35 pm »
    Update: First a little background. I originally had no spark so I replaced the internal coil, turns out the no spark issue was the kill switch. When I got it going is when I started having the kick back problem. I put the original internal coil back in and now it runs like a top. There's something different about that internal coil even though it is supposed to be a direct replacement.??? Very strange! But it's fixed.
    Re: El Tigre 5000
    « Reply #4 on: July 24, 2021, 03:15:49 pm »
    Great that you were able to fix it, great motors in these.  too bad there is no aftermarket replacement for the cdi units...
    72 Cheetah 440 sachs
    72 Cheetah 303 custom
    71 Puma 303 mod
    Brettm57
    • You can't have too many toys....
    Re: El Tigre 5000
    « Reply #5 on: July 24, 2021, 04:08:23 pm »
    If you bought an aftermarket stator, I'm not surprised at your result.
    Your aftermarket stator might work if you set the timing with a timing light.  It's kind of a PITA to do on these sleds, but it's the only way to be sure it's right.  It might have been triggering spark too soon, and that would make it kick back.
    1971 634 Puma, 1972 340/440 Puma, 1977 Pantera, 1983 EL-JAGRE, 1980 Jag w/295 Wankel power, 2003 Z 570, 1967 Rupp A-Bone/MC90, 1984 MXK Mirage/Briggs Flathead-alky fueled
