Author Topic: Hirth 650 axial pistons  (Read 5697 times)
Jetson
Re: Hirth 650 axial pistons
« Reply #30 on: May 29, 2021, 03:49:30 pm »
 :)  Thanks Adam. Looking forward to it.  8)
2013 F800 Sno Pro LTD
76 SST 440 FC
75 SST 440 FA Presidential
1974 Sabre Jet 650
    RetroF7
    « Reply #31 on: June 03, 2021, 12:37:04 am »
    Aren't these pistons still available for the ultralight engines?  Has anyone called Recreational Engineering in Ohio to inquire?
    « Reply #32 on: June 04, 2021, 06:44:08 am »
    I haven't seen anything. Idk if anything is still available for the 280R.  But a call to a hirth aircraft engine dealer would help.
    y2grey
    • I've never eaten Taco Bell or owned an Arctic Cat
    « Reply #33 on: June 04, 2021, 10:44:31 am »
    I have a Hirth 280r i picked up that is an aviation application. It's a single plug, the tag says 280r13E. It has a pto prop adapter, factory free air cooling, it has an aluminum deflector that bolts on the head bolt extensions (yes all of them) the flywheel has no provision for a recoil cup or point adjustment window. There were no external ignition components included. It was free so I figure I'm ahead of the game if I can salvage any parts from the top end.
    18 YAMAHA SIDEWINDER X-TX 141
    09 YAMAHA APEX 144 SC
    06 YAMAHA ATTAK
    03 YAMAHA RX1
    02 SKI-DOO RENEGADE 800
    79 YAMAHA SRX 440
    78 YAMAHA SRX 440
    77 YAMAHA SRX 44O SUPER MOD
    75 MERCURY SNO-TWISTER 440
    71 SKI-DADDLER XX 1650
