Author Topic: New project 1980 SRX  (Read 6379 times)
sdsnocop
Re: New project 1980 SRX
« Reply #45 on: July 26, 2021, 05:37:54 pm »
You guys are right. I should have known better. The water jacket is not open on the bottom of the cylinder. I found the leak. The water jacket manifold where the coolant enters the cylinders was weeping coolant which was running down the back of the cylinder and running along the base gasket making it look like the base gasket was leaking coolant. This is an easy fix which makes me happy. The throttle extension came today so now I will be less likely to be jumping the SRX off the front of the trailer.
13 Indy 600 SP
05 Arctic Cat M7
87 Polaris Indy 400 SKS
80 Yamaha SRX 440
74 Chaparral SSX 440
72 Skidoo TNT 440
    sdsnocop
    « Reply #46 on: August 02, 2021, 05:47:12 am »
    A little more progress on the SRX. I had some clear left over from a previous project so I sanded the hood and painted in some of the missing stripes and portion of the missing SRX decal. I shot the hood with 2K clear. The hood still has numerous stress cracks but it will look good going down the trail and should keep the hood decals from peeling off. I cut down the broken windshield I had, painted the inside of the shield black and shot clear on the outside. I like the look of the short windshield. If it snowed today I would be able take the SRX for a short ride. I will need to order a seat cover and figure out weather the seat foam is salvageable. I still need to find a bumper end, temp gauge, clutch cover, snow flap, carbides, carb filter pods, and tie rod end covers.
    13 Indy 600 SP
    05 Arctic Cat M7
    80 Yamaha SRX 440
    72 Skidoo TNT 440
    XCRacer440
    « Reply #47 on: August 02, 2021, 05:26:11 pm »
    I think it flows nicely with the black short windshield.  When do you usually start getting snow in the hills anyway?
    sdsnocop
    « Reply #48 on: September 16, 2021, 05:43:30 am »
    Back to work on the SRX. Brought back a few parts from Hay Days. New belt, carbides which need to be modified to fit, studs and K&N filter pods. I could not find a seat foam for the SRX but brought home an Enticer seat I am cutting down and modifying to fit. Cut a new seat board, reinforced the front seat pan. Rear seat pan was not bad shape. Now I am waiting on a seat cover to install. I have some minor trimming and to glue the foam to the edge of the board and seat pans. I did find a clutch cover I have to pick up locally.
    13 Indy 600 SP
    05 Arctic Cat M7
    80 Yamaha SRX 440
    72 Skidoo TNT 440
    SS440-80
    « Reply #49 on: September 16, 2021, 02:26:25 pm »
    Going to be super  :D
    A tip to get a nice smooth rounding on the seat foam, is to use a angle grinder with a sand disk. But use a fine size of sand disk.
    MY SLEDS:
    LYNX Boondocker RE 850 -18
    LYNX RAVE 600ace -12
    YAMAHA SRV -91
    YAMAHA SRV -90
    YAMAHA ET 400 T/R -89
    YAMAHA ET340T/R -84
    YAMAHA SRV 340 -82, Daughters edition.
    YAMAHA GP292B -73
    OCKELBO 6000 -86
    OCKELBO TRIOMAN -75
    2x JOHN DEERE SPRINTFIRE -83
    sdsnocop
    « Reply #50 on: September 21, 2021, 04:45:39 am »
    Seat is done. Not quite show quality but will work good for a rider. Seat cost me $80, $63 for the cover, $3 for the seat foam and $10 hardware. I did not include the cost of a new electric fillet knife since my old one took a dump.
    13 Indy 600 SP
    05 Arctic Cat M7
    80 Yamaha SRX 440
    72 Skidoo TNT 440
    mitchkem
    « Reply #51 on: September 21, 2021, 03:55:00 pm »
    looks great 8)
    sdsnocop
    « Reply #52 on: October 07, 2021, 04:42:22 pm »
    Installed new belt, and switch covers. Modified and installed carbides. Found a snow flap and bumper end on line. I still have to fix the small coolant leak on the water intake jacket. I took the SRX for its first run. Unloaded in the newly mowed highway ditch and took her for a rip. Slight bog off the line but pulled hard in the midrange. I have not started tuning yet. The 38mm carbs are straight out of a 500 indy. I am running rich but it is pointless to start tuning since it is 75 degrees and am at 3000 feet lower in elevation than I would be riding the SRX.
    13 Indy 600 SP
    05 Arctic Cat M7
    80 Yamaha SRX 440
    72 Skidoo TNT 440
    SS440-80
    « Reply #53 on: October 07, 2021, 07:06:08 pm »
    So good looking sled  :D
    MY SLEDS:
    YAMAHA SRV -91
    YAMAHA SRV -90
    YAMAHA ET340T/R -84
    YAMAHA GP292B -73
    OCKELBO 6000 -86
    OCKELBO TRIOMAN -75
