Author Topic: Going to be a SRV440  (Read 1869 times)
SS440-80
« on: November 09, 2020, 09:44:06 am »
My best friends son Johan got his  SS440 1981 many years ago, and it has been (ab)used a lot.  Most of it aint on photo, but some moments are captured  ;D
The hood has been open more than closed, always repairing something  :o
And many odd repairs it has been, both on the outside and the inside of the sled.  ::)
But the motorn has ALWAYS worked  :)
So when we got a SRV very cheap, we decided that we would build a SRV440.
It's a 1982 SRV:n with a 1981 cut up hood. Sled has a bad seat, worse skid and broken track and everything is dirty as hell.
The reason that the hood is cut open, is because the previous owner had mounted a Enticer 340 motor. But now it's gonna be a SS440-engine instead  8)
MY SLEDS:
LYNX Boondocker RE 850 -18
LYNX RAVE 600ace -12
YAMAHA SRV -91
YAMAHA SRV -90
YAMAHA ET 400 T/R -89
YAMAHA ET340T/R -84
YAMAHA SRV 340 -82, Daughters edition.
YAMAHA GP292B -73
OCKELBO 6000 -86
OCKELBO TRIOMAN -75
2x JOHN DEERE SPRINTFIRE -83
    SS440-80
    Re: Going to be a SRV440
    « Reply #1 on: November 10, 2020, 04:17:35 pm »
    Started to get the ET-engine out.
    Found a odd thing... the motor mounting plate was not bolted in the front  ???
    Motor out!
    Sad to see that the previous owner has made it easy for him self, cutting out the side wall on the PTO-side  ::)
    MY SLEDS:
    YAMAHA SRV -91
    YAMAHA SRV -90
    YAMAHA ET340T/R -84
    YAMAHA GP292B -73
    OCKELBO 6000 -86
    OCKELBO TRIOMAN -75
    SS440-80
    « Reply #2 on: November 13, 2020, 05:12:54 pm »
    Stripping
    Going to be another track and skid on the sled. And when the drive shaft is out I'm gonna mount new bearings.
    Skis in good shape, but the skins are not  :D But the plan is to get modern plastic skis.
    Wheels mounted to make it easy to wove the chassi around....
    Cleaning
    New side wall welded and the mounts for the ET-motor is grinded away.
    MY SLEDS:
    YAMAHA SRV -91
    YAMAHA SRV -90
    YAMAHA ET340T/R -84
    YAMAHA GP292B -73
    OCKELBO 6000 -86
    OCKELBO TRIOMAN -75
    SS440-80
    « Reply #3 on: November 16, 2020, 06:46:44 pm »
    Now the SS has to donate some parts to the project  :D
    First the engine
    Skid and track
    The Polaris skid has worked very well on the SS, so the plan was to use it on the SRV too
    But it needs welding, and we have no good welder for aluminum around here...
    So we decided to use a Phazer skid instead. Bought new shocks and the skid is ready for mounting.
    MY SLEDS:
    YAMAHA SRV -91
    YAMAHA SRV -90
    YAMAHA ET340T/R -84
    YAMAHA GP292B -73
    OCKELBO 6000 -86
    OCKELBO TRIOMAN -75
    XCRacer440
    « Reply #4 on: November 16, 2020, 08:11:09 pm »
    Wow that thing has taken some serious hits...i have seen guys rivet or bolt plates around their damaged holes on the rails for repairs before...i guess i never asked them if it worked or not as their project was in the summer...just a thought if you wanted to repair your other skid
    SS440-80
    « Reply #5 on: November 19, 2020, 04:23:11 pm »
    Now with the PZ-skid, it's no hurry to repair the Poo-skid. So I will look around if I can find someone who welds.
    MY SLEDS:
    YAMAHA SRV -91
    YAMAHA SRV -90
    YAMAHA ET340T/R -84
    YAMAHA GP292B -73
    OCKELBO 6000 -86
    OCKELBO TRIOMAN -75
    SS440-80
    « Reply #6 on: November 19, 2020, 04:26:27 pm »
    With the motor on the bench, I took it apart and put new oil seals on the crankshaft and new piston wrist pin bearings.
    A little oily behind the stator plate
    Bottom is off
    The oil pump gearing taken off. It won't be mounted again...
    Could not guess that the pump and gear could weigh almost 1,9 lbs.
    New oil seals
    and new needle bearings
    With the motor back together, I started to make a new left front motor mount
    I think it will work...
    MY SLEDS:
    YAMAHA SRV -91
    YAMAHA SRV -90
    YAMAHA ET340T/R -84
    YAMAHA GP292B -73
    OCKELBO 6000 -86
    OCKELBO TRIOMAN -75
    mr bolens
    « Reply #7 on: November 20, 2020, 03:40:23 pm »
    So you are going to use an electric tach?
    SS440-80
    « Reply #8 on: November 20, 2020, 07:41:24 pm »
    No, it won't be any tach. Not at this point anyway, maybe if Johan feels that the sled won't rev as it should I will mount a electric tach.
    MY SLEDS:
    YAMAHA SRV -91
    YAMAHA SRV -90
    YAMAHA ET340T/R -84
    YAMAHA GP292B -73
    OCKELBO 6000 -86
    OCKELBO TRIOMAN -75
    SS440-80
    « Reply #9 on: November 21, 2020, 03:51:20 pm »
    Took the TSS apart to check the condition on shocks and springs. Everything was in good shape.
    Then I mounted grease fittings on the TSS-arms
    MY SLEDS:
    YAMAHA SRV -91
    YAMAHA SRV -90
    YAMAHA ET340T/R -84
    YAMAHA GP292B -73
    OCKELBO 6000 -86
    OCKELBO TRIOMAN -75
    Skier76
    • CT and Southern Vermont
    « Reply #10 on: November 22, 2020, 01:05:51 pm »
    This is really cool! Thanks for sharing the pics! I enjoy these types of projects!
    1996 Puma 2-up
    1996 Jag
    SS440-80
    « Reply #11 on: November 22, 2020, 02:23:12 pm »
    Thanks  :)  Always good with threads that has a lot of pictures  :D
    MY SLEDS:
    YAMAHA SRV -91
    YAMAHA SRV -90
    YAMAHA ET340T/R -84
    YAMAHA GP292B -73
    OCKELBO 6000 -86
    OCKELBO TRIOMAN -75
    SS440-80
    « Reply #12 on: November 25, 2020, 07:53:36 pm »
    When I put the chaincase back together I used the smaller upper sprocket from the SS, and the bigger lower sprocket from the SRV. Giving me a lower gearing that will be good on our narrow curvy trails.
    The carb and airbox back on
    Then it was time for the gas tank, but I got a wiered feeling that I should check the fuel filter...
    And there was no filter left in the cage  ;D
    But I took a fuel pickup that was over from a John Deere and mounted in to the cage, and then back in the tank
    Next to be put back on was the plastic. But it was so bleached from sun, that I just had to do something...
    A hot air gun usually works well to bring back the black in plastic, but this time I almost gave up. But I kept on warming and finally it turned more black
    MY SLEDS:
    YAMAHA SRV -91
    YAMAHA SRV -90
    YAMAHA ET340T/R -84
    YAMAHA GP292B -73
    OCKELBO 6000 -86
    OCKELBO TRIOMAN -75
    SS440-80
    « Reply #13 on: November 29, 2020, 06:53:17 pm »
    A 121" track in better condition than the old 116" track
    The Phazer skid will work fine
    The exhaust was modified to fit the ET340 engine, but with som cutting and welding it fits the SS440 engine  :D
    Sprayed with Hot Paint
    looks good, hope it will hold
    MY SLEDS:
    YAMAHA SRV -91
    YAMAHA SRV -90
    YAMAHA ET340T/R -84
    YAMAHA GP292B -73
    OCKELBO 6000 -86
    OCKELBO TRIOMAN -75
    Skier76
    « Reply #14 on: November 29, 2020, 09:34:07 pm »
    Coming along nicely! I don't have any experience with it...but I've heard of a number of guys doing a 121" conversion on first gen Phazers. Should make a good difference!
    1996 Puma 2-up
    1996 Jag
