Welcome, Guest. Please
login
or
register
Unread Posts
Unread Replies
HOME
CLASSIFIEDS
EVENTS
RESOURCES
Forums
Forums
Board
Topic
Home
Help
Search
Calendar
Media
Register
The World Famous Bull Sessions
Show Us What You Are You Building?
Restorations
(Moderator:
ddub
1970 scorpion mark II
« previous
next »
Print
Pages: [
1
2
3
4
Go Down
Author
Topic: 1970 scorpion mark II (Read 4057 times)
oldcadman
SnoPro
west bend wi.
on:
September 06, 2020, 03:06:17 am »
i am starting to restore my 70 scorpion mark II, i wanted to start this in spring but with all the covid related stuff i was working 7 days a week since march but are now back to 5 days a week. this is my first snowmobile that i bought used in 1972 at the age of 14. i drove this sled 3 winters and sold it to my brother when i bought a still in the crate new left over 1974 295 eltigre. my brother drove it until 1979 when he traded it for a 90cc honda motorcycle. around 2010 i was invited to go look at some old sleds that a guy i worked with, father had in his barn. i was looking at a 1973 scorpion 400 r.v. they had for sale and i ended up buying and restoring when i spied a 70 a scorpion mark II across the barn and walked over to check it out. i told the father and son that i had one of these in the early 70's and as i was checking it out i opened the rear seat back and found a registration card with my brothers name on it. the father then said he traded a old honda motorcycle for the sled. i ended up buying the 73 400 r.v. and 70 markII for $250.00 each. i have left the 70 original and would start it up once a month, but because the track is junk i could not ride it. between the bad track and the in the chassis gas tank having some rust holes in it i decided to rebuild the sled so i can drive it.
here is the sled when i brought it back home.
the junk track
Logged
1970 scorpion mark II sachs single
1973 scorpion 400 rv
1973 scorpion 290 ET
2006 4 stroke panther
1972 stinger II 400 r.v.
1979 scorpion whip 440
1971 stinger 400
1970 stinger 400
never been bitten by a mosquito while snowmobiling
Advertisement
Sponsored Links
Remove Advertisements
oldcadman
SnoPro
west bend wi.
Re: 1970 scorpion mark II
Reply #1 on:
September 06, 2020, 03:15:53 am »
the first thing i did was cut out the top of the bad fuel tank and repair the rust thru holes. i decided i was going to do a plastic tank conversion which means i have to fab up a steering support as the original was part of the fuel tank.
here is the fabricated steering support.
Logged
1971 stinger 400
1970 stinger 400
oldcadman
SnoPro
west bend wi.
Reply #2 on:
September 06, 2020, 03:36:39 am »
for the track conversion i will be using the bogie system and track from a 71 scorpion stinger. however for the rear axle i will be using one off a 72 scorpion stinger II as they are 3/4'' instead of the 5/8'' on the 71 stinger. the drive axle will be off a 71 stinger also but i replaced the brittle white drivers with a pair of n.o.s. arctic cat black drivers. i end milled all the rivets off the bogies so i could sandblast and paint them and also replace the bearings. i then sandblasted the bogie suspension parts, rear axle assembly and the n.o.s springs i have been buying up whenever i could find them.
next was to paint all the metal parts and dye the bogie rubber parts. i reassembled the bogies with new bearings and stainless 10/32 bolts.
here is the rusty suspension before.
after blasting and during paint
and the finished parts
Logged
1971 stinger 400
1970 stinger 400
399jlo
BS Hall Of Fame Member
Reply #3 on:
September 06, 2020, 12:51:42 pm »
Looking good Rick!
Logged
PETT member #60
oldcadman
SnoPro
west bend wi.
Reply #4 on:
September 07, 2020, 01:13:24 am »
i had the day to myself and wanted to get all the fab work done on the sled so i can disassemble it and start the body work so it was out to the shop at 7:00 a.m. and start working. the first thing was to fab up the ball and socket exhaust i will be using instead of the leaky flex pipe.
next was to make and install a battery tray as i will be using a ccw 290 e-start engine on the sled instead of the sachs single that it came with.
i needed to weld on some hooks for a gas tank strap as i converted it over to a plastic tank.
i next needed to and some support to the foot rests as these bend very easy.
one of the reasons i put the sled together as i am doing the fab work is so there are no surprises after everything is painted. had i not done this i would not have caught the ignition switch bracket hitting the motor. i cut it off and welded it on the other side.
Logged
1971 stinger 400
1970 stinger 400
oldcadman
SnoPro
west bend wi.
Reply #5 on:
September 07, 2020, 01:20:24 am »
after checking the hood and bumper fitment is was time to disassemble everything. i need to clean up some welds and when i get some time i can start with body work.
Logged
1971 stinger 400
1970 stinger 400
Reply #6 on:
September 07, 2020, 10:51:34 am »
Nice work Rick. It looks like you've made a lot of progress and it's nice to see something new happening on the resto page.
Logged
oldcadman
SnoPro
west bend wi.
Reply #7 on:
September 13, 2020, 12:35:10 am »
i spent most of the day using a hammer and dolly to get about 50 dents and crease's flattened out enough so i only had to put a light coat bondo on. i taped off and applied roll on truck bed liner in the tunnel and under the running boards. you have to tape off where you don't want the bedliner to go so nuts, bolt's , axles and bearing retainers will fit correctly. i applied 2 coats about a 1 hour apart and then removed all the tape. if you wait to long to remove the tape you will never get it off. after letting everything cure overnight i will apply 2 coats of primer and block sand them with 320 grit in preparation for the black base coat.
Logged
1971 stinger 400
1970 stinger 400
399jlo
Reply #8 on:
September 13, 2020, 12:34:53 pm »
Sweet!
Logged
PETT member #60
oldcadman
SnoPro
west bend wi.
Reply #9 on:
September 26, 2020, 11:35:46 pm »
i had a few hours off free time today so i scrubbed the track down and applied 2 coats of sem vinyl gloss black dye to it. i have been doing the body work and block sanding for an hour every night after work for the last couple of weeks and now have the chassis ready for 3 coats of gloss black.
track before.
the track after
the tunnel with the final coat of primer block sanded down and ready for paint.
Logged
1971 stinger 400
1970 stinger 400
Mr_Plow
SnoPro
People for the Ethical Treatment of Tillotson's
Reply #10 on:
September 27, 2020, 08:35:40 pm »
The track turned out awesome!
Logged
My sled picture albums: Wild-One, '65 Arctic Cat, AMF, Others
https://skydrive.live.com/?sc=photos&cid=1a878d203f056b3a
Reply #11 on:
September 28, 2020, 11:18:33 am »
Logged
SnoPro
Reply #12 on:
October 01, 2020, 10:58:03 am »
Logged
72 Cheetah 440 sachs
72 Cheetah 303 custom
71 Puma 303 mod
oldcadman
SnoPro
west bend wi.
Reply #13 on:
October 02, 2020, 01:38:35 am »
i spent a couple of hours in the shop tonite bead blasting and rebuilding the clutch i will be using. i even had to make a special tool to pull the arm pins out.
Logged
1971 stinger 400
1970 stinger 400
SnoPro
Reply #14 on:
October 02, 2020, 07:57:18 pm »
Looks great. what clutch is that ?
Logged
71 Puma 303 mod
Print
Pages: [
1
2
3
4
Go Up
« previous
next »
Restorations
(Moderator:
ddub
Terms of Use
Copyright
Privacy Policy
Do Not Sell My Data
Manage Consent
