Author Topic: 1969 Skiroule SX-740 Adventure  (Read 6017 times)
mr bolens
Re: 1969 Skiroule SX-740 Adventure
« Reply #30 on: December 14, 2019, 08:56:04 pm »
Just remember that back then they did not have all the tools we have now to make things
    zoom
    • The whole fam damily in 1968
    « Reply #31 on: December 20, 2019, 11:23:53 pm »
    Pics of spacer without chain-case attached.  The large triangular hole is needed to install front axle bearing and flange.  Skiroule built theirs with a round hole, our bad. LOL
    zoom
    « Reply #32 on: December 20, 2019, 11:24:40 pm »
    more
    « Reply #33 on: December 21, 2019, 11:53:00 am »
    Uh ohhhh.  Gotta start all over........  ;D
    derwood
    « Reply #34 on: December 25, 2019, 02:47:51 am »
    Well, those French Canadians have smaller hands than us Americans with the fat fingers.
    Derwood
    I want more than I need.
    Everyone wants to change the world but no one wants to change themselves.
    « Reply #35 on: December 25, 2019, 12:46:58 pm »
    Derwood
    Yahh. I noticed that too.
    zoom
    « Reply #36 on: December 29, 2019, 07:15:21 pm »
    Another part on the SX-740 that is different from the rest of the 1969 Skiroule models is the steering post support hoop.  In order to span the engine and chain case spacer , the hoop has to be about 4 1/4 inches longer . One end  mounts to the running board instead of the top of the tunnel . This requires the hoop to also be 6 1/2 approx. longer, on that side.  We looked at this and thought , no big deal.  ;D Take some measurements off Chatham and Warning sled , buy the required size steel tubing and have it bent to specifications.  It turned out that no one or any place in our tri-state area does such bending . It's the O.D size that causes the problem. After hearing of our dilemma , DR. Mario offered to do the job for us. He has the equipment and know how.  :)   We sure appreciated the offer but the 1000 mile round trip was just not in the plans. Derwood and I got out the cut off wheels, hack saws and blow torches and got medieval on the part. ;)
    zoom
    « Reply #37 on: December 29, 2019, 07:21:17 pm »
    Pic
    zoom
    « Reply #38 on: December 29, 2019, 07:28:30 pm »
    We found threaded rod that just fit inside the tubing . Derwood cut the needed pieces from a donor frame .  We built a holding fixture. With that and all our reference pictures from Wisconsin and New York a friend , Brian Burns tacked it together for us.
    zoom
    « Reply #39 on: December 29, 2019, 07:34:25 pm »
    Pics        primed chassis  = ours         painted = Warning and Sawyer sleds
    zoom
    « Reply #40 on: December 29, 2019, 09:24:36 pm »
    So after having the hoop tacked and checking over pictures , a minor adjustment is needed.  The stirrup on the chain case side needs cut off and relocated about 3/4 inch.  I emailed Dan Nimsgern  , he sent me a new picture of that area .  With that new information ( picture taken from a different angle ) we could see that the stirrup needs moved. In preparation of more welding we have prepped the old exhaust area for plugging at that time.   Once again primer = ours    paint =  Warning sled
    zoom
    « Reply #41 on: December 31, 2019, 12:23:11 am »
    Other chassis changes : shorten, cut down and radius chain case side tunnel stiffening angle iron.  I believe it was easier for Skiroule , they likely started with a bare chassis.  Derwood has some suspicions that Skiroule in fact used 1968 chassis for these SX-740 sleds.  His thinking is at least partially based on Skiroule using 1968 type chassis ID plates . The two SX-740 we know of use this style serial # plate.  Anyway, on we go.  :)   The chain case clearance bulge in the running board had to be removed and the resulting hole greatly enlarged.  This was necessary to accommodate the nearly 3 1/2 inch wider area , to  be taken up by the chain case and the needed spacer. We the help of a wooden form we roughly formed a new longer and consequently deeper part . This part will need more work at a later date and welded in place. These Skiroule designed changes were all needed to fit the engine onto the narrow tunnel . Once again these changes could not have been made by Derwood and I  without the continuing help from New York and Wisconsin.
    zoom
    « Reply #42 on: December 31, 2019, 12:32:30 am »
    Pics
    zoom
    « Reply #43 on: December 31, 2019, 12:35:48 am »
    Pics
    zoom
    « Reply #44 on: December 31, 2019, 12:47:59 am »
    Most have heard this story.   Skiroule  built 10 1969 SX-740 sleds .    I don't know whether this is true or not. Never the less, Derwood and I are attempting to build this sled as if were the 11th. or last 1969 SX-740 that Skiroule built. The spare chassis for the factory race team , as it were.  ;) This is the reason we chose to move a stirrup 3/4 inch , even though to some eyes it makes little or no difference. Having said this , if we were find our original chassis or missing parts , we would be over joyed.  I hope all this text is interesting to some or all.  I guess that because this sled means so much to us , we are hoping it means just a little something to others.
