Author Topic: 75 Z Engine cleaning  (Read 1720 times)
RMK800
« on: September 12, 2019, 05:10:30 am »
Tried a new method of cleaning and shining the Z free air engine. I used to use crushed glass or sand to initial water blast clean the whole engine. Then glass bead water blast to smooth and polish the engine to a satin smooth finish better than factory by far. This time I went with crushed walnut to clean the engine as walnut is softer than the aluminum so I hoped it would result in less of a rough finish before glass bead water blasting. Then glass bead blasted the entire engine and carbs. My theory worked excellent so decided to post the results. First 3 pics are before pics.
79 TX 340
78 el Tigre 5000
76 TX 440
75 Sno Twister 440
75 340 Z
74 el Tigre 295
74 TX 440
    RMK800
    Re: 75 Z Engine cleaning
    « Reply #1 on: September 12, 2019, 05:16:19 am »
    These pics are of the final product. The walnuts cleaned the engine excellent and did not roughen the surface at all. If you just want to clean the engine just use walnuts and you will have a clean grime free engine without the roughed up look of typical abrasive media. I wanted a shiny finish that Glass beads provide. The glass beads actually smooth the aluminum so the grime does not have a place to grab onto. An engine I bead blasted 2 years ago and have raced a lot shows no evidence of dulling or collecting grime.
    79 TX 340
    78 el Tigre 5000
    76 TX 440
    75 Sno Twister 440
    75 340 Z
    74 el Tigre 295
    74 TX 440
    mr bolens
    « Reply #2 on: September 12, 2019, 02:01:52 pm »
    Did you do it with it all together or did you just put together to clean it
    RMK800
    « Reply #3 on: September 13, 2019, 02:08:38 am »
    Together. Sealed off all openings well.
    79 TX 340
    78 el Tigre 5000
    76 TX 440
    75 Sno Twister 440
    75 340 Z
    74 el Tigre 295
    74 TX 440
    polaris-case
    « Reply #4 on: September 13, 2019, 02:47:32 am »
    WOW   That looks awesome 👍   Dale
    mr bolens
    « Reply #5 on: September 13, 2019, 03:51:51 pm »
    Thanks
    Vics stuff
    • Go Big Or Go Home
    « Reply #6 on: September 13, 2019, 09:00:21 pm »
    I use ultra fine glass beads on all my bright work.
     Vic
    oldracer
    « Reply #7 on: September 21, 2019, 12:58:15 am »
    What kind of gun you use for that?
    RMK800
    « Reply #8 on: September 25, 2019, 04:31:49 am »
    pressure washer attachment from Princess Auto in Canada. Likely get the same in US
    79 TX 340
    78 el Tigre 5000
    76 TX 440
    75 Sno Twister 440
    75 340 Z
    74 el Tigre 295
    74 TX 440
    RMK800
    « Reply #9 on: September 25, 2019, 04:34:02 am »
     Vic
    What is the bead size number Vic that you use.
    79 TX 340
    78 el Tigre 5000
    76 TX 440
    75 Sno Twister 440
    75 340 Z
    74 el Tigre 295
    74 TX 440
    Vics stuff
    • Go Big Or Go Home
    « Reply #10 on: March 14, 2020, 08:22:12 am »
    RMK800   I use ultra fine glass. I think that it is 180 - 220 grit  @ 45 psi.
     Works great.
     Vic
