Author Topic: 1977 Polaris TX 250  (Read 16820 times)
cloughrin
Re: 1977 Polaris TX 250
« Reply #15 on: January 13, 2018, 01:37:32 pm »
Here is the only picture I have of the sled right now.
    LitrBox
    « Reply #16 on: January 13, 2018, 04:21:14 pm »
    Good looking sled as is. Should help restoration to have a straight and complete start
    "It's not about right and left. It's about right and wrong."
    RustedHistory
    • Tok, Alaska
    « Reply #17 on: January 14, 2018, 03:20:54 am »
    Great looking original condition sled, good luck to you on the project!
    1992 Yamaha Bravo 250
    1989 Yamaha Bravo 250 (Parts)
    1986 Yamaha Bravo 440 (Custom)
    1985 Ski Doo Tundra 250 LT
    1983 Yamaha Bravo 250
    1981 Ski Doo Alpine 503
    1978 Ski Doo Everest 440E
    1973 Rupp Nitro 340 (Incomplete)
    1970 Ski Doo Olympique 335E (299)
    If it's old and mechanical, I like it.
    RMK800
    « Reply #18 on: January 14, 2018, 04:42:17 am »
    Hello cloughrin. To clarify about blasting the engine. I abrasive water blast my engines with fine sand or crushed glass to remove all dirt and grime buildup. I then water blast with glass beads to smooth out the aluminum surface and creates a satin shine. I do not tear the engine apart to do this unless I am doing a tear down anyway. But then one must make covers for the intakes and exhaust ports and seal off any other openings and protect the PTO shaft and seal. I make simple 20 gage steel or aluminum covers and use silicone gasket maker for 100 % sealing and this works perfect. The blasting media will get in anywhere that you do not 100% seal up real good. See my restore project 75 440 Sno Twister.
    « Last Edit: January 14, 2018, 04:45:33 am by RMK800 »
    79 TX 340
    78 el Tigre 5000
    76 TX 440
    75 Sno Twister 440
    75 340 Z
    74 el Tigre 295
    74 TX 440
    cloughrin
    « Reply #19 on: January 14, 2018, 11:48:26 pm »
    Thank you for the replies. That motor looks great. Now I just have to find someone with a set up to help me out with this.
    cloughrin
    « Reply #20 on: January 16, 2018, 08:50:10 pm »
    A few more pics as I got it to the front of the shed. Hoping to get it into the shop this weekend. Pictures make it look better than what it is. The lighting is not great but I had belly pan redone when I first got it along with the seat. Belly pan was spray bombed with Polaris midnight blue paint. ( Will probably regret that).Not decided how far I am going to go with this thing yet....
    ShaunB_827
    « Reply #21 on: January 17, 2018, 05:42:18 am »
    Looks like a nice shape original as it is! Your plastics pieces (dash, tank, trunk lid, etc) are not faded or broken looking so thats a HUGE bonus and a good start to a resto! Looking forward to seeing more.  8)
    1972 Polaris Starfire 439
    1974 Polaris TX440
    1976 Polaris TX Starfire 250
    1977 Polaris TX-L 340
    1978 Polaris TX-L 340
    1978 Polaris TX340
    1979 Polaris TX-C 340
    1980 Polaris TX-C 340
    1981 Polaris TX-L 340
    cloughrin
    « Reply #22 on: January 17, 2018, 12:44:13 pm »
    Thank you. Trunk lid is excellent. Tank and dash are faded and need some work hard to tell in pictures. I got the sled moved to the shop last night so hopefully take some pictures in good light and start with a basic cleaning and put a plan together from there.
    cloughrin
    « Reply #23 on: January 19, 2018, 02:27:35 pm »
    Anyone have suggestions for rebuilding the master brake cylinder? I noticed it is very soft and low on fluid. Is there a seal kit for these available? I have never had one apart before.  Thanks
    acrneon
    « Reply #24 on: January 19, 2018, 03:21:33 pm »
    I don't what level of restoration you are doing, all correct or just a rider. The newer style master cylinder from the mid 90s makes things easier as you can remove it from the handle bar quickly. Parts are available from many sources.
    cloughrin
    « Reply #25 on: January 19, 2018, 04:58:05 pm »
    Not a professional restore by any means... But Iwould like to rebuild the existing brake cylinder if at all possible.
    Drift Buster
    • Reese, MI
    « Reply #26 on: January 19, 2018, 06:17:41 pm »
    Nice TX 250, I have bought rebuild kits from the Polaris dealer that worked, they were for a late 80's early 90's ATV's.  Have them show you the diagram and look for the same looking brake cylinder and it should be good.  Basically all you need is the cup and O ring anyway. Also I use Dot 5 silicone brake fluid in mine, if you spill some it will not eat the paint and it does not attract moisture. Don't mix the two types, flush the Dot 3 out and refill with Dot 5.
    cloughrin
    « Reply #27 on: January 19, 2018, 09:45:49 pm »
    Drift Buster: I will look into that this weekend. Thanks. Does anyone know what the center to center measurement should be from primary to secondary. Or crankshaft to jackshaft?
    acrneon
    « Reply #28 on: January 20, 2018, 02:54:21 am »
    Center distance is 12". Free download of service and parts manual at vintagesnow.com
    cloughrin
    « Reply #29 on: January 20, 2018, 03:38:18 am »
    Thanks ACRNEON. I did download and print everything I thought I needed. Must have missed that.
    Long story short this is what I came up with tonight as I started taking things apart. Engine number and model number. The way I read this the chassis is for a 250 and the motor is a 340? What would you guys do.. Change decals to match the engine? Find a 250?
