Author Topic: leak down pressure test kits  (Read 12408 times)
Re: leak down pressure test kits
« Reply #15 on: February 26, 2016, 03:47:34 am »
I guess ill have to get on this project..
    ilikesleds
    • I really Like Sleds
    « Reply #16 on: April 24, 2016, 11:51:13 am »
    I'll take one!
    United States Air Force Retired
    « Reply #17 on: April 24, 2016, 09:26:23 pm »
    What kind of exhaust blocking plates do people need?
    Ive gone ahead with the intake boot plugs.  Ill measure all the exhaust stud patterns on motors i have, but i dont have everything.  Try to make them work for multiple engines.  Dimensions from interested parties would help.
    « Reply #18 on: May 05, 2016, 10:27:48 pm »
    Heres a few pictures. Picked up the first of the carb boot test plugs.  They fit mikuni carb boots for 36-38 and 40-44 series carbs.  These will be tapped and fitted with air fittings on both ends.  Another run of plugs will not have a hole through them so you can block half of a twin if you like while testing the other half.
    « Reply #19 on: May 05, 2016, 10:32:49 pm »
    Here is a design for the exhaust blocking plate for pressure testing.  It has slotted mount holes with 70-80mm hole centers for 8mm bolts. Will come with a pressure gasket. Since no one responded. I wont be doing any other variations for different exhaust stud patterns.
    « Reply #20 on: May 06, 2016, 03:05:17 pm »
    With boots.
    sledcrazyinCT
    « Reply #21 on: May 08, 2016, 01:34:50 pm »
    excellent!
    « Reply #22 on: June 10, 2016, 10:13:23 pm »
    The test plugs are finished. Here's a couple. The solid version as well.  A twin kit will have one solid plug and one pressure fitting plug.  Working on exhaust blocking plates next.
    67Oly
    « Reply #23 on: June 11, 2016, 01:37:39 am »
    Looking on my small phone. Are those of rings?
    « Reply #24 on: June 11, 2016, 02:47:51 am »
    O-rings?   No they are grooves. They seat on the  rasied lip inside the mikuni carb boot.
    ilikesleds
    « Reply #25 on: June 11, 2016, 12:18:54 pm »
    Sorry for not keeping up.  Forgot to hit notify. Are you past exhaust measurements?  I will still take a complete kit.
    « Reply #26 on: June 11, 2016, 12:42:54 pm »
    Yes no one replied so im only doing a standard 2 bolt exhaust plate with hole centers slotted from 70-80mm c-c that should cover most appls. If it doesnt and people have 4 bolt exhaust or others they are sol.
    « Reply #27 on: August 06, 2016, 01:32:29 am »
    Here are the finished leak pressure test parts.   A delrin(fancy plastic) mikuni carb boot plug. Either tapped for 1/4 npt or solid.  The exhaust block off plates and an exhaust block off gasket.  The delrin plugs fit 38mm style and 40-44mm style mikuni carb boots.   The threaded plug you hook up a low pressure regulator or hand pump to pressurize the engine to 5-10 lbs. Any higher is not recommended and may blow out your seals.  The kit is sold in single, twin, or triple configurations with your choice of solid or tapped plugs.
    sledcrazyinCT
    « Reply #28 on: August 19, 2016, 02:13:46 pm »
    Haven't logged in for months.  Is there a link to pics and prices?
    « Reply #29 on: August 19, 2016, 09:25:14 pm »
    You should be able to see the pics just above..?
