Author Topic: Points timing question  (Read 862 times)
73 Cat guy
« on: May 25, 2017, 06:35:07 pm »
Never thought to check one against the other but, if you set the timing using a TDC gauge ( with dial indicator) and then check it with the timing marks (with a light or a "buzz box"), it should be right on the nuts right ?
    Re: Points timing question
    « Reply #1 on: May 25, 2017, 06:54:05 pm »
    If your setting the timing with a dial indicator you should be using a light( not like a timing light gun) or a buzz box. Only way to know the points just crack when the indicator reading is correct.      Seperate from that would be using a timing light gun with the engine running and checking marks on the flywheel or making marks on the clutch.   If done correctly they should be the same.      Dont forget some systems have advance cams which may introduce some error.  So personally the be all end all imo you should check the timing with light and engine running.
    Ski of Plenty
    • When a problem comes along...you must Whip it!
    « Reply #2 on: May 27, 2017, 02:10:22 am »
    With an energy transfer ignition (breaker points) a timing light is only useful to merely check the timing with the engine running. You cannot adjust the timing while the engine is running as you would on an engine with a distributor. The adjustments that you may need to make can only be done with the engine not running...and are so minute as to be indiscernible to the naked eye. Using a dial indicator and a continuity light or buzzbox is the only way to get the timing spot on to recommended specs. If you are looking for a good buzzbox, try Morris Magnetos. I purchased mine there online several years ago...reasonably priced and works great. It actually emits a loud continuous beep when the points open so your eyes can always remain on the dial indicator. I've timed numerous different snowmobile engines this way. Some will require you to hold the advance mechanism...but this is usually not terribly difficult if you are patient and careful. It's always easiest if you can do it with the engine out of the sled. I personally have never found it necessary to use a timing light afterwards...but if you're unsure of your work it's a good way to recheck it.
    « Last Edit: May 27, 2017, 02:14:47 am by Ski of Plenty »
    Jesus said, "All that I have is yours!" The socialist says "All that you have is mine!"  Winston Churchill
    2012 Polaris IQ LXT 550
    1994 Polaris Trail Deluxe
    1977 Scorpion Sting 440
    1975 Scorpion Whip 340
    1975 Rupp Nitro F/A 440
    2muchfun
    « Reply #3 on: May 27, 2017, 08:27:16 am »
    Points=buzz box,dial indicator/flywheel marks
    CDI=timing light  and if you have carb or motor issue,you'll never get it timed right ;)
    73 Cat guy
    « Reply #4 on: May 27, 2017, 03:49:10 pm »
    AND... you only advance the timing advance when using the dial indicator, NOT when using the timing marks RIGHT ?
    ColorMeGone
    • PETT 94
    « Reply #5 on: May 27, 2017, 05:58:54 pm »
    Don't forget your edge gap. ???
    All the sudden I have all triples...
    73 Cat guy
    « Reply #6 on: May 27, 2017, 09:01:21 pm »
    Regarding edge gap, does this ever change ? what would cause it to ? I noticed the range given in spec's, that it is quite a wide range.
    2muchfun
    « Reply #7 on: May 27, 2017, 09:38:58 pm »
    Yes edge gap is pretty well taken care,Timing is more critical. As far as advancing the cam with the use of a dial indicator not necessarily.Some engine manufactures time there engine differently and you should go by there procedures and specification. They will tell you what to do with the cam. From what I know generally if it is less than .100 BTDC that is a retard measurement   More than a .100 BTDC would be advanced cam generally. Again get the specification and go by them.  Also set the point gap to specification mag side First then time engine mag side, then time PTO side by varying point gap.  Some engine manufactures give you both static and running specification and mark the flywheel with such,so try to get the information.  I like the static timing procedure so I don't have to hold the cam in advance position.
    FRAIDY CAT
    • I'd rather be driving a Titleist
    « Reply #8 on: May 28, 2017, 12:48:58 am »
    I like to set up the dial indicator once. I mark the flywheel with the min/max spec and am done with it. Factory marks get a bad rep around here but they work just fine for general use, Racing is a whole different ball game.
    Ski of Plenty
    « Reply #9 on: May 28, 2017, 01:10:16 am »
    On a JLO/Cuyuna...I prefer to sweat the details. Just sayin...
    2muchfun
    « Reply #10 on: May 28, 2017, 01:16:28 am »
    Yes general use is one thing. Racing is another,but I will still use the indicator for both cylinders.  Again gap the mag side points first then use the dial indicator to set the stater to the mag side.  Then set points to the preferred BTDC measurement for the PTO side. ;)
