Author Topic: JLO twin  (Read 3209 times)
Todd K.
JLO twin
« on: March 24, 2017, 04:19:40 am »
I found this motor in the barn finds, is it anything special? or just another JLO, weird carb adaptor, and long starter cup? what did this motor go on? motor numbers  type, 2F-400-1   217 ... 398CCM   ps/n   motor number 399  36490
    JLOpower
    • Official Curmudgeon
    • Fresh Snow makes me Whiz
      • Ski Whiz Rescue Mission
    Re: JLO twin
    « Reply #1 on: March 24, 2017, 10:10:08 am »
    Doubt that it is special. A photo inside the starter cut would help. I'll bet it isn't JLO. Carb adapter is a GEM, not being used for it's original application. Cant for the life of me understand why someone would need to do that. The Tilly would work in the upright position. The reason can't be for steering shaft clearance.
    Do Not believe everything you think.
    Re: JLO twin
    « Reply #2 on: March 24, 2017, 12:53:36 pm »
    Almost looks Ski- Whizy!
    chapguy
    Re: JLO twin
    « Reply #3 on: March 24, 2017, 01:37:02 pm »
    That's what I was thinking....
    If it aint a Chap, it's crap !!!!!
     But all vintage sleds are cool........
    Desmo878
    • Henniker, NH; Thrillbilly Capital of the East
    Re: JLO twin
    « Reply #4 on: March 24, 2017, 01:52:39 pm »
    It looks like that GEM adaptor would actually put it into the steering shaft! I have a few Ski Whiz's, & don't think that would work in any of them because of the steering shaft. That's why they used the angled intake. JLO made a straight intake, but it won't work in most old sleds for this reason. The super long recoil cup, not sure what to make of that???
    70 MF 350SS   71 MF 500SST
    72 MF 400WT   72 AC Lynx (x 2)
    72 Moto Ski Capri  72 Boa Ski Mark II
    70 Yam. SL 396  75 Suzuki 440 Fury
    74 El Tigre 440   72 Whip-It Prowler
    72 Yam. SW 433  75 AC 340 Cheetah
    72 SnoPrince GT400  72 Suzuki Nomad 360 (x2)
    71 StarCraft Snow Star 79 Kaw. 440 Invader
    indybosch
    Re: JLO twin
    « Reply #5 on: March 24, 2017, 01:57:40 pm »
    Probably put the long starter cup on for rope starts.
    zuknomad
    • still ridin' that old crap
    Re: JLO twin
    « Reply #6 on: March 24, 2017, 03:30:39 pm »
    Yup, after the original starter puked and they didn't have the patience to fix it...
    anyone can run a new sled; it takes some dedication to ride crap!
    PETT #76
    skfox
    Re: JLO twin
    « Reply #7 on: March 24, 2017, 05:31:21 pm »
    1970 -1973 Fox Tracs?
    wankel303
    Re: JLO twin
    « Reply #8 on: March 24, 2017, 05:32:25 pm »
    Looks like a JLO 399 from a 1971 Arctic Cat Panther to me ( 4 bolts on the heads rather than the 6 used by the Cuyuna motors) but I am more familiar with the one-lunger JLOs than the twins.  The Cat would have used that down drafting intake manifold to clear the steering column.  Clutch would have had to have been swapped, the 45 degree G.E.M. Intake added and some "minor" modifications made to the recoil.  These recoils were fairly prone to issues and those little "stand-off like clampy-thingys" always disappeared in the shop someplace as soon as you took them off.
    JLOpower
    Re: JLO twin
    « Reply #9 on: March 24, 2017, 07:09:52 pm »
    Quote
    The clutch and starter cup isn't, for sure. Massey's twin cylinder engines all used motor mounts that were 4 flat spring steel bars, so that motor plate is wrong for a MF too. The engine designation leads me to think it's one produced right around the time Rockwell sold to Scorpion. Still that doesn't narrow it down much.
    73400tk
    Re: JLO twin
    « Reply #10 on: March 24, 2017, 07:45:44 pm »
    It wouldn't be a cat motor as its a 2F-400-1, the cat motor was a LR399-2 though it does have the angled up intake the both cat and massey did use. It could be from on of the many off brand sleds that used JLO. The 2F-400 motors were not used until 72. Its the high performance 400 with the extra transfer port and smaller bore. The 2F has 64.87mm piston and the LR has a 64.93mm piston. As well the rings and ring gap pins are different due to the difference in the transfer port. The 2F also used chrome spun rings while the LR used just regular carbon steel springs.
    LR399-2:                28 HP
    2F400-1 through 6: 43 HP
    My mistress is a pair of 1973 Scorpion Super Stinger 400TK's (one yellow and one red)
    Todd K.
    Re: JLO twin
    « Reply #11 on: March 25, 2017, 04:48:58 am »
    WOW, Thats great news, i thought that JLO  sticker looked different the others i have seen. im thinking of making a little hot rod PUMA, looks like a good power plant, THANKS FOR THE INFO!!!
    JLOpower
    Re: JLO twin
    « Reply #12 on: March 25, 2017, 10:14:54 am »
    The sticker looks correct for that era.
    Desmo878
    Re: JLO twin
    « Reply #13 on: March 25, 2017, 12:04:08 pm »
    My 73 Whip It, 73 SnoPrince, & 72 MotoSki have the LR399-2 in them, along with 2 Masseys I have. Pretty common engine back then in consumer type sleds. No hot rod, but torquey. Sticker is correct for them. Surprised it still looks that good!!
    scorpion tkx 890
    Re: JLO twin
    « Reply #14 on: March 26, 2017, 02:12:11 am »
    This motor is not a 2F as the cylinders dont have the welch plugs on the sides for the extra transfer ports. Looks like a LR to me
