Author Topic: Making chicken soup from chicken poop  (Read 16787 times)
thepupstain
  • one chicken nugget shy of a happy meal.
« on: August 10, 2016, 11:27:21 am »
I picked this one up last winter totally apart and finally getting time to work on it. ..pretty sad shape.
   Somewhere in this pile theres supposed to be a 76 440 TX.  It wont be totally stock so I guess itll be a custom?
« Last Edit: August 10, 2016, 12:00:15 pm by thepupstain »
If quitters never win, and winners never quit,then who is the fool that said "Quit while youre ahead?"
    thepupstain
    Re: Making chicken soup from chicken poop
    « Reply #1 on: August 10, 2016, 11:32:12 am »
    Fresh from the "pile".  Not much to go by and I will be schooling on how a TX is put together...this is just how I got it.
    « Last Edit: August 10, 2016, 11:44:27 am by thepupstain »
    thepupstain
    « Reply #2 on: August 10, 2016, 11:37:27 am »
    The original belly pan was thrown out by the previous owner so I found this one on ebay.  Much fitting involved between there being a new pan,very rough hood, smashed hood hinge,and bent bumper. Ive gotta get better at taking more pix of the carnage.
      After I get stuff fitted it will get stripped again and soda blasted.  Blasting in hot weather is a dull sport so it'll be a while before that happens.
    « Last Edit: August 10, 2016, 12:03:47 pm by thepupstain »
    thepupstain
    « Reply #3 on: August 10, 2016, 11:56:12 am »
    I got to do some of the fun stuff while it was nasty hot outside.
    Brokenleg
    • " It's Just Steady"
    « Reply #4 on: August 10, 2016, 08:13:26 pm »
    Looks great. How did you clean all your engine parts ?  Brokenleg
    thepupstain
    « Reply #5 on: August 11, 2016, 10:47:38 am »
    Thanks Brokenleg.
     I cleaned the aluminum engine parts with a homemade vapor blast unit that sprays glass bead with water and air pressure.
    The internals were just done in the parts washer.
    « Last Edit: August 11, 2016, 10:56:25 am by thepupstain »
    kawidave
    • Calm down. Eat a cookie. Happy now?
    « Reply #6 on: August 11, 2016, 09:59:03 pm »
    Motor looks great
    Member of:
    Illinois Valley Winter Sports Club.
    « Reply #7 on: August 11, 2016, 10:53:42 pm »
    looks great so far. I would love to see a pic of that vapor sand /water blaster. sounds like a good tool to have, the parts look amazing.
    2 x 71 Puma dual carb 303
    70 panther 303w
    thepupstain
    « Reply #8 on: August 12, 2016, 12:09:46 pm »
    Thanks guys.   Here are a couple pix of what I used.  I didn't know if it would work so I didn't invest tons of time making it.
       The blue tank had a bladder in it that was removed and is set up like a pressure blaster with an air nipple in the top and a bung to put the water in the top.
      The small hopper has the glass beads in it and mounts to the side of the bench.  It works, but its slow..Ive never seen a real one but the idea intrigued me.   I like building, but didn't have the ambition to make an entire cabinet....Im also not sure how much it'll get used.
     Anything commercial I found so far was made in the UK and pricey. Those have a windshield wiper and use a full cabinet.
    Im sure if the right mind was at it, it can be improved upon.
    « Reply #9 on: August 12, 2016, 09:52:41 pm »
    looks pretty nice. thanks for posting it. slow is fine for me, more time than $$
    70 panther 303w
    Mario
    • Dr Mario's, In Biz Since 1998
    « Reply #10 on: August 19, 2016, 04:07:43 am »
    Pretty cool!
    Ignorant people find me irritating. Isn't that precious
    It takes dedication, and commitment to make a difference..
    Please don't expect me to take you seriously, if your tinfoil hat is leaning to the far left,,,,,
     and mercury is not a good replacement for tinfoil,,,,
    Have a nice day!
    thepupstain
    « Reply #11 on: November 15, 2016, 01:28:52 pm »
    Been busy at work but finally got a chance to mock up some parts and did a batch of blue stuff...The skid and new track were fitted as well but I forgot to take pics of that part.
     For paint, I used what I call "summa paint"- which is summa dis and summa dat. It started out as acrylic equipment enamel for tint mixed with urethane clear and hardener. Ive done this before with good results..it can be wet sanded and buffed and has good chemical resistance to fuel.
    Im getting kinda anxious to start building so I just started blasting and painting. I tried soda blasting the tunnel and it worked out well on the aluminum.  Ive still got a ton of little stuff to paint before I can get busy building. maybe by the weekend I'll have a skidframe done.
         Not sure if I need to switch to decaf or get a better camera :-[
    « Last Edit: November 16, 2016, 01:26:26 pm by thepupstain »
    skidoogrampa
    « Reply #12 on: November 15, 2016, 09:19:40 pm »
    The soup stock is starting to smell good!
    It's not a snowmobile "disease"...it's a snowmobile "condition".
    polaris-case
    « Reply #13 on: November 15, 2016, 09:30:47 pm »
    The tank looks like a well pressure tank ??  What kinda pressure did you use ??  Looking good so far    Dale
    thepupstain
    « Reply #14 on: November 16, 2016, 11:21:10 am »
    Thank you guys!  Yes the soup's gettin better...I started with better poop than the last one. I just wish I could take better pics.
      Polaris case, that was a well tank, but I removed the bladder so it functions like a plain tank. As far as pressure goes I cant remember exactly.  There is a cheapo harbor freight regulator thingy with a gauge but I pretty much ignored it and was toning down the pressure with the shop regulator. As it sits, the water tank is set up like a pressure pot sand blast unit.  I use super fine glass bead that is pulled to the gun under vacuum.  Its very mild (slow)
    « Last Edit: November 22, 2016, 11:57:07 am by thepupstain »
